SO-ARM100 / SO-101
The SO-101 is the next-generation version of the SO-100 robot arm, originally designed by RobotStudio in collaboration with Hugging Face, with improved wiring, easier assembly and updated leader-arm motors.
STS3215 servos, 3D-printed parts, Motor Control Board
TheRobotStudio
SO-101 robot arm from RobotStudio and Hugging Face, made to work with LeRobot
SO-ARM100 / SO-101
No photo in the source; GitHub repository card, served from HardwareLab.No creator demo video in the repository README.
By TheRobotStudio
The SO-101 is the next-generation version of the SO-100 robot arm, originally designed by RobotStudio in collaboration with Hugging Face, with improved wiring, easier assembly and updated leader-arm motors. Build it from the bill of materials and 3D-printed parts or buy a kit, then set it up with the LeRobot library.
  • The next-generation version of the SO-100 arm, originally designed by RobotStudio in collaboration with Hugging Face: improved wiring, easier assembly (no gear removal) and updated leader-arm motors.
  • Designed to work with the open-source LeRobot library.
  • Build it yourself (bill of materials, 3D-printed or ordered parts, assembly guide) or buy assembled arms or a parts kit.
  • Optional hardware includes a raised leader base and different camera mounts.
Skill level
  • 7 × STS3215 Servo 7.4V, 1/345 gear (C001)
  • 2 × STS3215 Servo 7.4V, 1/191 gear (C044)
  • 3 × STS3215 Servo 7.4V, 1/147 gear (C046)
  • 2 × Motor Control Board
  • 1 × USB-C Cable 2 pcs
  • 2 × Power Supply
  • 1 × Table Clamp 4pcs
  • 1 × Screwdriver Set
  • 3D-printed parts (leader and follower)
  • Table Clamp 2pcs [optional]
LeRobot
As an Amazon Associate HardwareLab earns from qualifying purchases.
7 × STS3215 Servo 7.4V, 1/345 gear (C001) Parts for two arms (follower and leader)Required
2 × STS3215 Servo 7.4V, 1/191 gear (C044) Required
3 × STS3215 Servo 7.4V, 1/147 gear (C046) Required
2 × Motor Control Board RequiredView on Amazon
1 × USB-C Cable 2 pcs RequiredView on Amazon
2 × Power Supply RequiredView on Amazon
1 × Table Clamp 4pcs RequiredView on Amazon
1 × Screwdriver Set Phillips #0 and #1 recommendedRequired
3D-printed parts (leader and follower) Or order printed partsRequired
Table Clamp 2pcs OptionalView on Amazon
Parts used: Motor Control Board (Amazon)As an Amazon Associate HardwareLab earns from qualifying purchases.
Skill level
  1. Source the components from the bill of materials
  2. 3D print the parts, or order them
  3. Follow the assembly guide
  4. Set up the SO-101 with the LeRobot tutorial
A follower and a leader arm form a teleoperation setup; after sourcing the parts you set it up with the LeRobot tutorial.
Motor debuggingFeetech Software Any Windows PC over USB
Skill level
Source the parts, print them, assemble with the guide, then set up with the LeRobot tutorial.
  • The 7.4V follower motors have 16.5kg.cm stall torque at 6V; the 12V version has 30kg.cm but needs a 12V 5A+ power supply. The leader arm is always 7.4V.
  • Buy links cover only the US, EU, CN and JP for now, and prices and items vary by location.
  • The SO-100 docs are deprecated.
  • Tested print settings (README)
    1. Material: PLA+
    2. Nozzle Diameter and Precision: 0.4mm nozzle diameter at 0.2mm layer height or 0.6mm nozzle at 0.4mm layer height.
    3. Infill Density: 15%
  • Extend it with XLeRobot, a dual-arm mobile robot with two SO101 arms and a LeKiwi base.
The SO-101 is the next-generation version of the SO-100 arm, originally designed by RobotStudio in collaboration with Hugging Face. The README lists what changed: improved wiring, easier assembly with no gear removal, and updated motors for the leader arm. You can build one yourself by sourcing parts from the bill of materials, 3D printing the parts or ordering them, and following the assembly guide, or buy assembled arms or a parts kit from vendors listed in the repo, including Seeed Studio. The classic setup is a follower arm plus a leader arm for teleoperation with LeRobot, and the repo also has optional designs such as a raised leader base and different camera mounts. The SO-100 docs are now marked deprecated.
Source: github.com/TheRobotStudio/SO-ARM100#readme
  • STS3215 servos
  • 3D-printed parts
  • Motor Control Board
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/so-arm100/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/so-arm100/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
  1. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L23
  2. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L25
  3. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L33-L41
  4. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L47
  5. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L111-L114
  6. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L191-L193
  7. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L75-L79
  8. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L80
  9. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L81
  10. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L82
  11. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L83
  12. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L84
  13. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L85
  14. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L86-L104
  15. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L37
  16. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L100
  17. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L258
  18. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L33-L44
  19. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L73
  20. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L70
  21. github.com/TheRobotStudio/SO-ARM100/blob/a758567c3978dfeefe282ede0500085a48fe8f78/README.md?plain=1#L31
