iPhone-teleoperated robot arm
Imitation learning with iPhone-based teleoperation of a low-cost robot arm.
low-cost arm, iPhone
trzy
Teach a cheap arm by moving your iPhone.
By trzy
  • low-cost arm, iPhone
imitation learning policy
  1. To discover the serial port on which the robot is connected, run python -m server --list-serial-ports.
  2. To run the robot server, specify the serial port the robot is connected to: python -m server --serial-port=*usb*.
  3. To record episodes to the cube directory using camera 1: python -m server --serial-port=*usb* --camera=1 --record-to=cube.
  4. To train a model on episodes stored in cube: python -m act --train --dataset-dir=cube --checkpoint-dir=cube/checkpoints.
  5. First, launch the inference server: python -m act --infer --checkpoint-file=cube/checkpoints/policy_best.ckpt.
  6. Next, run the robot server in inference mode: python -m server --serial-port=COM4 --infer.
The phone's pose drives the arm while you collect demos that train a policy.
  • Once a few dozen episodes have been collected, a policy can be trained.
  • Make sure to specify the same cameras; if the data was collected using two cameras, --camera=0,1.
  • The default camera is camera 0; you will need to experiment to figure out which is which on your system.
  • low-cost arm
  • iPhone
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/iphone-teleop-arm/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/iphone-teleop-arm/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
