ESP32s3 LLM Cluster
A distributed inference engine that runs a sliced 0.5B 1.58-bit (BitNet) language model across a cluster of seven ESP32-S3 microcontrollers.
7x ESP32-S3 over SPI
Low-Zi-Hong
Seven ESP32-S3s daisy-chained to run a 0.5B ternary LLM.
ESP32s3 LLM Cluster
By Low-Zi-Hong
  • 7x ESP32-S3 over SPI (board)
0.5B BitNet 1.58-bit LLM
A master node runs the tokenizer and embeddings, and the other six run the attention and MLP layers in a pipeline. The boards pass activations over a high-speed SPI daisy chain. It builds on earlier single-node and distributed ESP32-S3 LLM experiments.
More ESP32 builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/esp32s3-llm-cluster/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/esp32s3-llm-cluster/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
