Needle 2 ESP32
A 45-million-parameter language model doing grammar-guaranteed tool calling entirely on one ESP32-S3: type a request and the board's RGB LED does what you asked, with no network.
- andrisgauracs
45M-parameter LLM offline on an ESP32-S3 turning English into valid commands.
- Runs offline
- Yes, per the source
- ESP32-S3 (board)
- 45M-param needle 2 LLM
An independent C99 engine (about 3,700 lines) reads the model weights from 16 MB of flash and uses 8 MB of octal PSRAM for its KV cache. Output is constrained so every tool call is valid JSON. It runs at about 1.87 tokens per second, roughly 25 seconds per request with reasoning turned off.
[](https://hardwarelab.dev/projects/needle-2-esp32/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/needle-2-esp32/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 23 in Local LLM Rigs & Edge Agents
ESP32s3 LLM Cluster
Seven ESP32-S3s daisy-chained to run a 0.5B ternary LLM.
- 7x ESP32-S3 over SPI
Advanced259
Muse Gadgets SDK
Meta’s open SDKs for connecting Muse to ESP32 and Raspberry Pi gadgets.
- ESP32 boards
- Raspberry Pi (3B+, 4, 5 or Zero 2 W) or another Linux computer with Bluetooth LE
Intermediate2.7K
ESP32 iPhone Agent
An ESP32-S3 board lets an AI model use a real iPhone: no computer at run time, no jailbreak.
- Seeed XIAO ESP32S3 (plain, 8MB PSRAM; any ESP32-S3 with native USB + PSRAM)
- iPhone on iOS 18+ with cellular data
- Lightning to USB Camera Adapter (Lightning iPhones only)
Intermediate4.8K
PFor
A 180.9M-parameter MoE language model and agent on a $6.80 ESP32-P4.
- WT9932P4-Tiny (ESP32-P4 v1.3, 32MB PSRAM, 16MB flash)
Advanced$6.80 (Wireless-Tag store)12
