Muse Gadgets SDK
Meta’s open SDKs for connecting Muse to ESP32 boards and Raspberry Pis
- Get an SDK token and review the Gadget SDK Terms; every gadget needs a token to pair.
- Pick the ESP32 device SDK for a board, or the Linux device SDK for a spare Raspberry Pi.
- In the Muse app, turn on Developer mode under Settings, Devices.
- Pair the gadget: look for devices whose names start with MuseGadget.
Steps condensed from the creator's guide.
- 2.2K (GitHub)
- ESP32 boards
- Raspberry Pi (3B+, 4, 5 or Zero 2 W) or another Linux computer with Bluetooth LE
- Muse, through the Muse app
- Accounts needed
- Muse SDK token from gadgets.muse.ai
Parts list
- ESP32-C5 DevKitC-1 (quickest start) or another listed ESP32 board [10]
- USB cable that carries data [11]
- Raspberry Pi 3B+, 4, 5 or Zero 2 W, or another Linux computer with Bluetooth LE [optional] [12]
- The Muse app on your phone [13]
Prices and notes: Parts and requirements
- Skill level
- Run Muse Code in esp32/, or install ESP-IDF v6.0.1 and run idf.py build and flash
- In the Muse app: Settings > Devices > Developer mode, then Add Device; press BOOT when the light breathes blue [18]
Meta released ESP32 and Linux device SDKs for connecting Muse to displays, buttons, sensors and actuators on ESP32 and Raspberry Pi gadgets; on a Linux gadget Muse can run commands and move files, and you can hack in your own commands for sysadmin chores or a Home Assistant setup.
- Open source devices you build yourself: program an off-the-shelf ESP32 board or set up a Raspberry Pi, then connect Muse to displays, buttons, sensors and actuators. [1]
- ESP32 Device SDK: add a screen for images, audio in and out, or other sensors. [2]
- Linux Device SDK: Muse can run shell commands, read and write files and report health (uptime, load, memory, disk, temperature). [3]
- Gadgets pair with the Muse app on iOS and Android under Settings > Devices, in Developer mode. [4]
The creator's prompts
First prompt for Muse Code (ESP32) [5]
Build this firmware for my ESP32-C5 DevKitC-1 and flash it.Follow-up prompts for Muse Code (ESP32) [6]
Watch the serial log and tell me when it's ready to pair. I have a Waveshare ESP32-S3 AMOLED board. Build the UI for it. Add support for my board. It's an ESP32-S3 with 16 MB flash, a button on GPIO 0 and no PSRAM. Make the status light half as bright.Things to ask Muse on a Linux gadget [7]
What's using all the disk space on my Pi? Install Home Assistant on my Pi and tell me how to open it. Every morning at 7, check if my Pi's backups ran and tell me if they didn't.
| ESP32-C5 DevKitC-1 (quickest start) or another listed ESP32 board [10] | Works as-is with its status light and BOOT button | Required | |
| USB cable that carries data [11] | Required | ||
| Raspberry Pi 3B+, 4, 5 or Zero 2 W, or another Linux computer with Bluetooth LE [12] | Raspberry Pi OS Bullseye or later, Debian 11+ or Ubuntu 22.04+, 32- or 64-bit | Optional | |
| The Muse app on your phone [13] | Required |
Device SDKs and firmware connect Muse to your displays, buttons, sensors and actuators; on a Linux gadget Muse can run commands and move files, and you can add your own commands.
- Skill level
Quickest path: install Muse Code, clone the repo and ask it to build and flash; the README also gives the manual ESP-IDF build. [18]
- Every gadget needs an SDK token to pair; the README says to review the Gadget SDK Terms first. [14]
- Muse gets the same access to the machine as the account you install it for, including sudo if that account has it. [19]
- Community devices: pairing has no manufacturer verification and can’t prevent an active man-in-the-middle attack, so set it up on a trusted network. [20]
- The README warns that tinkering may brick boards or void warranties. [21]
Muse Gadgets are open-source devices you build yourself and pair with the Muse app on iOS or Android. The repository holds two SDKs: an ESP32 device SDK for adding a screen, audio in and out or other sensors to an off-the-shelf board, and a Linux device SDK that turns a spare Raspberry Pi or Linux box into a gadget, with your own commands for sysadmin chores or Home Assistant. Setup has a few required steps: get an SDK token and review the Gadget SDK Terms, since every gadget needs a token to pair, then turn on Developer mode in the app under Settings, Devices and look for devices prefixed MuseGadget. Each directory includes an AGENTS.md for coding agents. The README calls it built "just for fun" and warns that tinkering may brick boards or void warranties. It is Apache 2.0 licensed.
- ESP32 boards
- Meta (facebookincubator): Creator
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L26-L29
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L37
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L17-L86
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L45-L47
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L42-L63
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L65-L76
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L93-L97
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L38
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L101-L105
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L31-L33
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L34
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L32-L35
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L40
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L40-L43
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L29-L40
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L17-L88
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L53-L56
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/esp32/README.md?plain=1#L36-L151
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L88-L89
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/linux/README.md?plain=1#L74-L77
- github.com/facebookincubator/muse-gadget-sdk/blob/f60347aeb851a1fe9438cfc388721776aa24f275/README.md?plain=1#L31-L33
[](https://hardwarelab.dev/projects/muse-gadget-sdk/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/muse-gadget-sdk/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 22 in Local LLM Rigs & Edge AgentsDaedalus voice terminal
An ESP32 voice terminal for a home AI running OpenClaw.
- ESP32
Needle 2 ESP32
45M-parameter LLM offline on an ESP32-S3 turning English into valid commands.
Advanced193
