ESP32 iPhone Agent
v2 of Henry Yuan's (@iamhenryyuan) agent: just the phone and an ESP32-S3 board.
- Seeed XIAO ESP32S3 (plain, 8MB PSRAM; any ESP32-S3 with native USB + PSRAM), iPhone on iOS 18+ with cellular data, Lightning to USB Camera Adapter (Lightning iPhones only), Mac with Xcode (one-time flash and build only), Vision-model API key (OpenAI-compatible)
- @iamhenryyuan
- Est. cost:
- $7.00
An ESP32-S3 board lets an AI model use a real iPhone: no computer at run time, no jailbreak.
The creator: @iamhenryyuanOriginal post
v2 of Henry Yuan's (@iamhenryyuan) agent: just the phone and an ESP32-S3 board. The ESP32-S3 is both the AirPlay receiver and a USB mouse and keyboard, and an iPhone app runs the agent against any OpenAI-compatible vision model. Every run is kept on the phone and can be replayed step by step. Code: onehumanbeing/esp32-iphone-agent (MIT).
- Seeed XIAO ESP32S3 (plain, 8MB PSRAM; any ESP32-S3 with native USB + PSRAM) (board)
- iPhone on iOS 18+ with cellular data, Lightning to USB Camera Adapter (Lightning iPhones only), Mac with Xcode (one-time flash and build only), Vision-model API key (OpenAI-compatible)
- Any OpenAI-compatible vision model (planner + actor)
The iPhone mirrors its screen over AirPlay to the ESP32-S3, which runs its own Wi-Fi hotspot and passes the H.264 stream to the ESP32 Agent app on the same phone over Bluetooth (BLE). The board is also plugged in as a USB mouse and keyboard, so with AssistiveTouch a click is a tap and a drag is a swipe. The app sends what it sees to any OpenAI-compatible vision model, which plans and acts, and it calibrates the pointer itself. The phone reaches the model over cellular data. No computer at run time and no jailbreak. Setup: 1) flash the board with arduino-cli (ESP32 core 3.3.x, NimBLE-Arduino 2.5.1) using hardware/flash.sh; 2) build the iOS app in Xcode (a free Apple ID works, re-signed every 7 days); 3) in the app, pair over Bluetooth, join the board's hotspot and pick Screen Mirroring, then "ESP32 Agent", turn on AssistiveTouch and enter the model endpoint and key; 4) type a task and press Start. v1 (a Mac or Linux computer running UxPlay and a Python server) is kept on the repo's legacy branch and tag v0.1.0.
The clever part is that the ESP32 is both the agent's eyes and hands. The board opens its own Wi-Fi hotspot and appears in the iPhone's Screen Mirroring list, forwarding the H.264 AirPlay stream to an iPhone app over BLE without decoding it. It also acts as a USB mouse and keyboard, so with AssistiveTouch on, clicks become taps and drags become swipes. The app sends screenshots to any OpenAI-compatible vision model and runs a planner and an actor. Because the pointer is relative, the app re-homes it in a corner and corrects misses before precise taps. The README's warning: only follow its own install steps and never run commands posted in issues. The older computer-based version is kept on a legacy branch.
- Lightning to USB Camera Adapter (Lightning iPhones only)
- Mac with Xcode (one-time flash and build only)
- Vision-model API key (OpenAI-compatible)
Where to buy
- XIAO ESP32S3 at Seeed Studio(affiliate link, disclosure)
[](https://hardwarelab.dev/projects/esp32-iphone-agent/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/esp32-iphone-agent/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 23 in Local LLM Rigs & Edge Agents
Muse Gadgets SDK
Meta’s open SDKs for connecting Muse to ESP32 and Raspberry Pi gadgets.
- ESP32 boards
- Raspberry Pi (3B+, 4, 5 or Zero 2 W) or another Linux computer with Bluetooth LE
Intermediate2.7K
Needle 2 ESP32
45M-parameter LLM offline on an ESP32-S3 turning English into valid commands.
Advanced209
ESP32s3 LLM Cluster
Seven ESP32-S3s daisy-chained to run a 0.5B ternary LLM.
- 7x ESP32-S3 over SPI
Advanced259
