NASA JPL Open Source Rover
An open-source, build-it-yourself, scaled-down version of the six-wheel rover design JPL uses on Mars, made entirely from consumer off-the-shelf parts with a Raspberry Pi as its brain.
rocker-bogie chassis, motors, onboard computer
License:
Apache-2.0
nasa-jpl
Build JPL’s scaled-down six-wheel Mars rover yourself
No photo in the source; GitHub repository card, served from HardwareLab.JPL's README links a community build video
By nasa-jpl
An open-source, build-it-yourself, scaled-down version of the six-wheel rover design JPL uses on Mars, made entirely from consumer off-the-shelf parts with a Raspberry Pi as its brain. It is meant as a teaching and learning project and a research platform for rugged terrain; no prior skills are required.
  • A build-it-yourself, scaled-down version of the six-wheel rover design JPL uses to explore Mars, made entirely of consumer off-the-shelf (COTS) parts.
  • Rocker-bogie suspension keeps all six wheels on the ground over obstacles; a differential pivot offloads weight between sides; six-wheel Ackermann steering.
  • A Raspberry Pi is the brain; anything that talks to a Pi (Bluetooth, WiFi, USB devices) can be interfaced into the control system.
  • Specs: ~1.6 m/s top speed (subject to motor selection), 10 motors, aluminum structure.
  • With a 7.2Ah battery and some rough-terrain driving, expect at least 3 hours of drive time.
Skill level
Apache-2.0 (source)
  • 6 × Wasteland Wheel (144mm diameter, 52mm width)
  • 6 × 5203 Series Yellow Jacket Planetary Gear Motor (26.9:1, 223 RPM)
  • 4 × 2000 Series Dual Mode Servo (25-2, Torque)
  • 3 × Roboclaw 2x7A Motor Controller
  • 1 × PCA9685 steering servo driver
  • Raspberry Pi 3, 4 or 5 and SD card
  • LiPo battery over 14V (a 4s works well)
  • Brain board and motor board PCBs
  • USB gamepad or remote controller [optional]
camera for object identification and tracking (suggested upgrade)
6 × Wasteland Wheel (144mm diameter, 52mm width) Required
6 × 5203 Series Yellow Jacket Planetary Gear Motor (26.9:1, 223 RPM) Drive wheel motorsRequired
4 × 2000 Series Dual Mode Servo (25-2, Torque) Required
3 × Roboclaw 2x7A Motor Controller Required
1 × PCA9685 steering servo driver Required
Raspberry Pi 3, 4 or 5 and SD card Only the 5 can connect to the Roboclaws and run Bluetooth at the same timeRequired
LiPo battery over 14V (a 4s works well) The README recommends over 4000mAhRequired
Brain board and motor board PCBs Required
USB gamepad or remote controller Not technically required, but highly recommendedOptional
  • Computer for setup: Basic familiarity with Linux, ROS, Git and Python helps; the rover code is in the osr-rover-code repository
Skill level
  1. Order parts (the Parts List Readme)
  2. Create the wiring
  3. Solder the PCB and install it
  4. Build the body, rocker-bogies, drive and corner assemblies
  5. Set up the rover code on the Raspberry Pi
A Raspberry Pi is the brain; rocker-bogie suspension, a differential pivot and six-wheel Ackermann steering copy the Mars rovers’ driving mechanics.
BrainRover code from osr-rover-code Raspberry Pi
Motor controlRoboclaw 2x7A motor controllers and a PCA9685 steering servo driver Electrical
Skill level
Beginner · “No prior skills or knowledge is required.”
No less than 100 person-hours, in five stages: order parts, wiring, electronics, mechanical assemblies, then the rover code.
  • Takes no less than 100 person-hours to build, and could be significantly more.
  • Don’t discharge a LiPo battery too far: it shortens battery life and can make it hard or impossible to recharge.
  • A 12V battery won’t work adequately: the 12V regulator needs a dropout voltage on top of 12V, hence over 14V.
  • Add upgrades on the Raspberry Pi: sonar for collision detection, an IMU, a camera for object identification and tracking, sensor packages, solar panels or a robotic arm.
JPL’s rover is a scaled-down version of the six-wheel design used on Mars, built entirely from consumer off-the-shelf parts, mostly goBILDA mechanical components. It has 10 motors, an aluminum structure and a top speed around 1.6 m/s depending on motor choice. It copies the real rovers’ driving mechanics: a rocker-bogie suspension that keeps all six wheels on the ground over obstacles, a differential pivot that offloads weight from one side to the other, and six-wheel Ackermann steering. The project has been iterated since 2017, is aimed at teaching mechanical, electronics and software skills with no prior experience required, and was designed with expansions like a head display and robot arm in mind. The README points to other open-source alternatives that are cheaper but slower, less strong and more fragile.
Source: github.com/nasa-jpl/open-source-rover#readme
  • rocker-bogie chassis
  • motors
  • onboard computer
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/open-source-rover/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/open-source-rover/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
  • Open Duck Mini
    A miniature version of the BDX Droid by Disney, about 42 centimeters tall with its legs extended, that the team is making walk with reinforcement learning.
    • 3D-printed parts
    • servomotors
    • onboard computer
    Advanced · Our suggestion4.7K
  • Nous-Girl: StackChan robot with Hermes Agent memory
    Beta firmware that turns an M5Stack StackChan into a talking desk robot with faces, DJ mode and an optional Hermes Agent brain.
    • M5Stack StackChan K151 (CoreS3, ESP32-S3)
    • USB-C cable
    • A computer for the voice server (only macOS on Apple Silicon tested so far)
    Intermediate · Our suggestion35
  • MOSS
    A modular home robot you can build from parts you already own.
    • Raspberry Pi (optional)
    • depth camera
  • JBR-001
    An Arduino UNO Q desk robot that reacts to what it sees.
    • Arduino UNO Q 2GB
    • USB camera via USB-C hub
    • Modulino Distance/Buzzer
    • +2 more
    Intermediate17
  • DinoDesk AI
    A LEGO desk robot that chats with local Gemma 4.
    • Raspberry Pi
    • LEGO body
    • Pirate Audio LCD/speaker
    • +2 more
    Intermediate13
  1. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L9
  2. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L45-L47
  3. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L49
  4. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L30-L32
  5. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L51
  6. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L135
  7. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L17
  8. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L13-L19
  9. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L42
  10. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L228
  11. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L230
  12. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L237
  13. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L232
  14. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L160
  15. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L169-L171
  16. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L91
  17. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L223-L230
  18. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L119-L133
  19. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L119
  20. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/README.md?plain=1#L53
  21. github.com/nasa-jpl/open-source-rover/blob/0bea824015778922d4d7e373fbf56a112efea46d/parts_list/README.md?plain=1#L239
