Digital Picture Frames & E-InkIntermediate · Our suggestion
Kindle + Claude Code
Claude Code jailbroke a Kindle over USB, then stripped the Amazon bloat
Original post
Image hot-linked from the original post.The creator's post shares a photo, not a video, so there's no demo to embed. See the post on X.
By Adrian (@adriandlam_)
Kindle Paperwhite (12th gen)
Claude Code
Parts list
  • Kindle Paperwhite (12th gen) [5]
Prices and notes: Parts and requirements
Part of: Hack a gadget you already own →
Agent-assisted Kindle modding shared on X by @adriandlam_: he connected his Kindle Paperwhite (12th gen) over USB, gave Claude Code the kindlemodding.org docs and let it jailbreak the Kindle, then removed the Amazon bloat and added Tailscale.
  • “connected the kindle over usb and let claude code jailbreak the kindle” [1]
  • “removed all the Amazon bloat + added tailscale” [1]
  • Claude Code worked from the kindlemodding.org docs: “i literally just gave it the docs lol” [2]
  • Read-later on the Kindle: “anytime i'd like to read something later, i save the article using readeck then it downloads + syncs with my home server”, and “when my kindle syncs i get it on the kindle!” [3]
  • Books from a home server: “i pull books off shelfmark which auto import into CWA, which then syncs to the kindle” [4]
Kindle Paperwhite (12th gen) [5]The creator's model: “i have the kindle paperwhite 12th gen”Required
Claude Code worked from the kindlemodding.org docs with the Kindle connected over USB. The creator says he “literally just gave it the docs”. No guide, code or commands were published, and this page doesn't add any.
AgentClaude Code [1]Connected to the Kindle over USB
Remote accessTailscale [1]Kindle
Read-laterreadeck [3]Home server
Book libraryShelfmark and CWA [4]Home server
  • Recent Kindle firmware may be patched against this: kindlemodding.org says firmware updates “can block jailbreaking methods”. [6]
  • kindlemodding.org describes jailbreaks as different methods that lead to one goal, “as other methods become patched”. [7]
  • The creator wasn't sure it would still work after updates: “i also install updates pretty regularly so not sure”. [5]
  • The creator notes jailbreaking is against Amazon's terms: “"jailbreaking" is against amazon toc”. [8]
  • kindlemodding.org's FAQ asks “Will this void the warranty on my Kindle device?” and answers “Probably.” [9]
  • No build guide, code or repo was published. HardwareLab doesn't give steps or commands; kindlemodding.org is the reference the creator used. [2]
  1. x.com/adriandlam_/status/2111845968492790095
  2. x.com/adriandlam_/status/2112221222767661349
  3. x.com/adriandlam_/status/2111862779636514996
  4. x.com/adriandlam_/status/2112221709134876881
  5. x.com/adriandlam_/status/2112222572519858522
  6. kindlemodding.org/jailbreaking/prevent-auto-update/#:~:text=These%20updates%20can%20block%20jailbreaking%20methods
  7. kindlemodding.org/jailbreaking/#:~:text=as%20other%20methods%20become%20patched
  8. x.com/adriandlam_/status/2112220609770119246
  9. kindlemodding.org/jailbreaking/jailbreak-faq.html#:~:text=Will%20this%20void%20the%20warranty%20on%20my%20Kindle%20device%3F
The photo and original post belong to the creator.
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/kindle-claude-code/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/kindle-claude-code/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
