Life Dashboard
A low-power heads-up display for everyday life running on a second-hand Kindle, now in its second version after years of daily use.
Hacked Kindle
davidhampgonsalves
A low-power everyday-life dashboard on a hacked Kindle.
Life Dashboard
By davidhampgonsalves
  • Hacked Kindle
Version 2 is written in Go and uses FBInk for text layout and image output on the Kindle's e-ink screen. The rewrite moved away from a Rust front end that needed a cross-compiling toolchain, after weather APIs the dashboard depended on kept shutting down.
Life Dashboard is the second version of a Kindle heads-up display, and its README explains the design trade-offs honestly. Generating the image on the Kindle meant cross-compiling for an old ARM-7 softfloat target, and the dashboard broke whenever a weather API it used shut down (Magicseaweed, Forecast.io and DarkSky are named). Version 2 moves the logic to an API Gateway and Lambda backend written in Go, using the tdewolff/canvas library for text and image generation; the Kindle just curls the PNG and shows it with FBInk. That way the API logic can change without touching the device or a cross-compiler. Setup starts with a jailbreak and SSH, with Kubrick in a VM as the recovery path if the Kindle bricks. Kindle Dash on HardwareLab is a related approach.
Source: github.com/davidhampgonsalves/Life-Dashboard#readme
  • Hacked Kindle
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/life-dashboard/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/life-dashboard/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
