GPT Home
A Raspberry Pi smart-home assistant pitched as a better alternative to commercial speakers.
Raspberry Pi, USB mic, speaker
judahpaul16
ChatGPT at home on a Raspberry Pi.
GPT Home
By judahpaul16
A Raspberry Pi smart-home assistant pitched as a better alternative to commercial speakers. Uses LiteLLM so you can swap model providers.
  • Raspberry Pi (board)
  • USB mic, speaker
LiteLLM (multiple providers)
Pi listens via mic, transcribes, routes to an LLM via LiteLLM, speaks back and calls integrations.
GPT Home is a Raspberry Pi assistant built on LiteLLM and LangGraph, and the README's integration list shows how far it goes beyond chat: OpenAI, Spotify, Philips Hue, OpenWeatherMap and Open-Meteo, alarms, reminders, CalDAV calendars, persistent memory and display support, with Zigbee2MQTT still unchecked. Setup is a script followed by one required step, adding an API key; through LiteLLM it supports 100+ providers, and the key can also be set in the web interface at gpt-home.local/settings. It runs in Docker, so it should work on other Linux systems, though the author only vouches for the versions in the compatibility table, and any USB or 3.5 mm speaker and mic supported by ALSA or PortAudio should work. Safety gotcha: never connect a battery directly to the Pi; use a UPS or battery power supply.
Source: github.com/judahpaul16/gpt-home#readme
  • Raspberry Pi
  • USB mic
  • speaker
More Raspberry Pi builds
This page is a short summary written by HardwareLab. Build steps, code and photos belong to the creator; follow โ€œView originalโ€ for the full project.
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/gpt-home/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/gpt-home/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
