Trmnl Firmware
The open-source firmware for the TRMNL e-ink display, a battery-powered e-paper screen that shows plugins and dashboards rendered on a server.
- TRMNL e-paper device (ESP32-C3)
- usetrmnl
Open firmware for the TRMNL e-paper display.
By usetrmnl
- TRMNL e-paper device (ESP32-C3) (board)
- plugins incl. LLM-generated content
After Wi-Fi setup through a captive portal, the device swaps its MAC address for an API key and then simply polls the server's display endpoint for its next image. The ESP32-C3 spends most of its time in deep sleep to save battery, waking on a timer or a button press. Errors are reported back to the server as logs.
The README's power section is the interesting read. TRMNL OG uses an ESP32-C3, and deep sleep with a timed wake-up can get to about 4 µA at 3 V, but TRMNL has to wake on a button press, and keeping that GPIO active averages about 100 µA, which the authors calculate would let a 2500 mAh battery last roughly 25,000 hours asleep. A normal update takes about 10.5 seconds, and most of the energy goes to Wi-Fi between the 3 and 9 second marks. After Wi-Fi setup through a captive portal, the device swaps its MAC address for an API key and friendly ID, then only requests display images, and it sends logs to the server if a response looks wrong. Gotcha: the main branch can break; flash tagged releases or use the Flash Assistant.
[](https://hardwarelab.dev/projects/trmnl-firmware/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/trmnl-firmware/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 40 in Digital Picture Frames & E-Ink
Sticky Remote
A reTerminal Sticky becomes a dedicated e-ink Apple TV and lights remote through Home Assistant.
- Seeed reTerminal Sticky (ESP32-S3, 3.97-inch 800×480 touch e-paper, 750 mAh battery, magnet back)
- USB-C cable
- Apple TV or another Home Assistant media_player
Beginner · Our suggestion6
unidex
A pocket e-ink OS that turns voice notes into Obsidian Markdown.
- Waveshare ESP32-S3 1.54" e-paper board
Intermediate83Claude Pager
An e-ink pager for approving Claude's tool calls from across the room.
- 296x128 e-ink
- 3 buttons
Siyun ePaper Therapist
Pocket e-paper companion that listens and responds with Azure OpenAI.
- Seeed XIAO ESP32S3 Sense
- e-paper display
Intermediate0
Eink Ai Calendar
An ESP32 e-ink calendar with an AI picture that exists only for today.
- Waveshare e-Paper ESP32 driver board
- Waveshare 5.65" 7-colour e-ink
- 5000 mAh battery
Intermediate5
