Sticky Remote
François Gilbert (@Frankynov) turned the Seeed reTerminal Sticky into an e-ink remote for an Apple TV or another Home Assistant media_player and one or two lights.
Seeed reTerminal Sticky (ESP32-S3, 3.97-inch 800×480 touch e-paper, 750 mAh battery, magnet back), USB-C cable, Apple TV or another Home Assistant media_player, One or two Home Assistant lights
Beginner · Our suggestion
License:
MIT
Control Apple TV and lights from one e-ink panel
Sticky Remote
By François Gilbert (@Frankynov)
François Gilbert (@Frankynov) turned the Seeed reTerminal Sticky into an e-ink remote for an Apple TV or another Home Assistant media_player and one or two lights. The creator built this first experiment with help from Claude. The firmware is MIT-licensed; v0.7.3 was released on November 13, 2026. A browser demo previews the setup wizard without a device.
  • Apple TV controls: d-pad, Back, Home, play/pause, ±10-second skip, seek and volume, alongside artwork and what is playing.
  • One or two Home Assistant light tiles toggle lights and adjust brightness.
  • The reTerminal Sticky can show a sleep clock; Sleep after and Clock while asleep are configurable.
  • A web wizard in Chrome or Edge flashes the reTerminal Sticky over USB-C and sets it up from the browser, with no tools to install.
MIT (source)
  • Seeed reTerminal Sticky (ESP32-S3; 3.97-inch 800×480 touch e-paper; 2.4 GHz Wi-Fi; 750 mAh battery; magnet back)
  • USB-C cable (USB connection from the reTerminal Sticky to the setup computer)
Claude (used by the creator to build the firmware, simulator and flasher)
Seeed reTerminal Sticky ESP32-S3; 3.97-inch 800×480 touch e-paper; 2.4 GHz Wi-Fi; 750 mAh battery; magnet back · Board price in USD; shipping and duties extra.Required$49.90(affiliate link, disclosure)Seeed Studio, checked
USB-C cable USB connection from the reTerminal Sticky to the setup computerRequired
$49.90 for the reTerminal Sticky; player, lights and Home Assistant hardware extra
Prices: $49.90 at Seeed Studio(affiliate link, disclosure) (checked )
  1. Open frankynov.ovh/sticky/ in Chrome or Edge on a computer, connect the reTerminal Sticky over USB-C, and run the connect-and-install step.
  2. In the wizard’s Wi-Fi step, select a network detected by the Sticky and enter its password; wait for the connection check.
  3. Connect the wizard to Home Assistant, then use Your remote to choose the player, its remote and one or two lights; save the configuration.
  4. Add the Sticky to Home Assistant through ESPHome and enable Allow the device to perform Home Assistant actions. Use the wizard’s final checklist and press a light or player tile to test it.
ESPHome firmware on the ESP32-S3 sends touchscreen actions to Home Assistant over Wi-Fi. Home Assistant controls the player and lights; this is not a Bluetooth Apple TV remote. The browser flasher configures Wi-Fi, Home Assistant and the remote without tools to install.
  • Battery life with Sticky Remote firmware has not been measured. Seeed rates the reTerminal Sticky hardware at about 7 days on standby; that is not measured Sticky Remote runtime.
  • The player and lights depend on Home Assistant: if Home Assistant is down, the Sticky cannot control them. It does not send Bluetooth commands directly to Apple TV.
  • Frankynov calls this a first experiment; the reTerminal Sticky firmware still needs sleep, wake and battery checks on real hardware.
  • Seeed reTerminal Sticky (ESP32-S3, 3.97-inch 800×480 touch e-paper, 750 mAh battery, magnet back)
  • USB-C cable
  • Apple TV or another Home Assistant media_player
  • One or two Home Assistant lights
More ESP32 buildsMore Seeed reTerminal builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/sticky-remote/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/sticky-remote/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
