RIO Mini
Desktop companion robot powered by ROS2 with an Ollama LLM and ESP32 micro-ROS for the body.
ESP32, servos, host PC
botforge-robotics
A desktop robot with ROS2, Ollama and micro-ROS.
RIO Mini
By botforge-robotics
  • 2 × N20 6V 60 RPM Micro Metal Gear Motor
  • 1 × Mini 3Pi Car N20 Caster Robot Ball Wheel
  • 2 × 34mm Mini Car N20 Motor Wheel Rubber Small Wheel
  • 1 × ESP32 Base PCB
  • 1 × ESP-32 Development Board(30-Pin)
  • 1 × Type-C USB 5V 2A Step-Up Boost Converter
  • 1 × 1000mAh 3.7V Single Cell LiPo Battery
  • 1 × VL53L0X ToF Laser Ranging Sensor
  • 1 × 1pc WS2812B 5V RGB LED
  • 1 × MX1508 Motor Driver
  • 1 × MG995 Servo Metal Gear
  • 1 × Aluminum Servo Horn 25T
  • 1 × Mobile Holder
  • 1 × Screws & Fasteners
  • 1 × Slide Switch
  • 1 × 3D Printed Body Parts
  • 1 × RIO Ros2Sense Mobile App
Ollama, ROS2
2 × N20 6V 60 RPM Micro Metal Gear Motor Required
1 × Mini 3Pi Car N20 Caster Robot Ball Wheel Required
2 × 34mm Mini Car N20 Motor Wheel Rubber Small Wheel Required
1 × ESP32 Base PCB Required
1 × ESP-32 Development Board(30-Pin) Required
1 × Type-C USB 5V 2A Step-Up Boost Converter Required
1 × 1000mAh 3.7V Single Cell LiPo Battery Required
1 × VL53L0X ToF Laser Ranging Sensor Required
1 × 1pc WS2812B 5V RGB LED Required
1 × MX1508 Motor Driver Required
1 × MG995 Servo Metal Gear Required
1 × Aluminum Servo Horn 25T Required
1 × Mobile Holder Required
1 × Screws & Fasteners Required
1 × Slide Switch Required
1 × 3D Printed Body Parts Required
1 × RIO Ros2Sense Mobile App Required
  1. LiPo 3.7V to IP5306 5V to ESP32 VIN/5V, MX1508 VM, Servo V+, WS2812B V+ and TOF V+, with COMMON GND.
  2. ToF SDA to ESP32 GPIO21 (SDA); ToF SCL to ESP32 GPIO22 (SCL).
  3. MX1508 IN1 to ESP32 GPIO25, IN2 to GPIO26, IN3 to GPIO27, IN4 to GPIO13; OUTA+/- to Motor Left terminals, OUTB+/- to Motor Right terminals.
  4. ESP32 GPIO17 to Servo Signal (MG996R); ESP32 GPIO16 to WS2812 DIN.
  5. While mounting motors and wheels, ensure no more than 1.5mm gap between the wheel and bottom base edge.
  6. Set the servo to 180° before mounting the arm between the servo horn and servo body.
ROS2 + Ollama on the host; ESP32 runs micro-ROS for motors and display.
  • Head pitch control has safety limits of 150-180°.
  • No more than 1.5mm gap between the wheel and bottom base edge.
  • ESP32
  • servos
  • host PC
More ESP32 builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/rio-mini/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/rio-mini/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
  1. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L151-L151
  2. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L152
  3. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L153-L153
  4. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L154
  5. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L155-L155
  6. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L156-L156
  7. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L157-L157
  8. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L158-L158
  9. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L159
  10. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L160-L160
  11. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L161-L161
  12. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L162
  13. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L163
  14. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L164
  15. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L165
  16. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L166
  17. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L167
  18. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md
  19. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L78-L78
  20. github.com/botforge-robotics/rio_mini_ros2/blob/5b194d65007d1427c5ff5e7384df29a68cf968c8/README.md#L257-L257
