OpenCat / Petoi
OpenCatESP32 runs the OpenCat quadruped robotics framework on BiBoard, an ESP32-based development board designed for multi-degree-of-freedom legged robots with up to 12 servos.
- Petoi kits, ESP32 board, servos
- Intermediate · Our suggestion
- PetoiCamp
The OpenCat quadruped robotics framework on Petoi’s ESP32 BiBoard
By PetoiCamp
OpenCatESP32 runs the OpenCat quadruped robotics framework on BiBoard, an ESP32-based development board designed for multi-degree-of-freedom legged robots with up to 12 servos. It is the codebase for current-generation Petoi hardware: the Bittle X robot dog and the Nybble Q robot cat.
- Runs the OpenCat quadruped robotics framework on BiBoard, an ESP32-based development board designed for multi-degree-of-freedom legged robots with up to 12 servos.
- BiBoard is the control board for the Bittle X mini robot dog (with voice control) and the Nybble Q mini robot cat.
- ESP32 dual-core at 240 MHz, Wi-Fi and Bluetooth built in, up to 12 servos and Arduino IDE compatible; hardware and software are both open source.
- For an open source robot dog for research, running ROS, deploying a vision model, or room to experiment, the README calls BiBoard the right foundation.
- BiBoard
- Petoi kit: Bittle X robot dog or Nybble Q robot cat
- deploying a vision model (BiBoard), voice control (Bittle X kit)
| BiBoard | ESP32-based development board for up to 12 servos | Required | |
| Petoi kit: Bittle X robot dog or Nybble Q robot cat | Required |
- Select ESP32 Dev Module in the Arduino IDE
- Apply the README’s board settings
- Follow the full setup: Upload Sketch for BiBoard
BiBoard’s ESP32 dual-core at 240 MHz handles real-time servo coordination for up to 12 servos, with Wi-Fi and Bluetooth built in, and it is programmed from the Arduino IDE.
| Framework | OpenCat quadruped robotics framework (OpenCatESP32) | BiBoard |
Set the Arduino IDE to ESP32 Dev Module with the README’s board settings, then follow the full setup guide.
- For the older NyBoard (ATmega328P), use the main OpenCat repo instead.
- The older Bittle and Nybble (NyBoard) are discontinued; BiBoard is the current platform.
Arduino IDE settings (ESP32 Dev Module)
| Setting | Value | |---|---| | Upload Speed | 921600 | | CPU Frequency | 240 MHz (WiFi/BT) | | Flash Frequency | 80 MHz | | Flash Mode | QIO | | Flash Size | 4 MB | | Partition Scheme | Default 4MB with spiffs | | Core Debug Level | None | | PSRAM | Disabled |
- Community builds include AI and computer vision applications, Raspberry Pi robotics projects, NVIDIA Isaac simulations and reinforcement learning, and SLAM with ROS using Bittle and Raspberry Pi.
Inspired by Boston Dynamics’ Spot, OpenCat started in a dorm at Wake Forest University in 2016, with the goal of making agile quadruped robots affordable and hackable enough for researchers, educators and makers. The README counts 30,000+ robots shipped in 60+ countries and 20+ academic papers citing the platform. OpenCatESP32 is the codebase for current-generation Petoi hardware: BiBoard’s dual-core ESP32 adds Wi-Fi and Bluetooth, up to 12 servos and Arduino IDE compatibility, and the README pitches it for research, running ROS or deploying a vision model. BiBoard is the control board for the Bittle X robot dog, which has voice control, and the Nybble Q robot cat; the older NyBoard-based Bittle and Nybble are discontinued. Community builds include AI and computer vision applications, NVIDIA Isaac simulations and reinforcement learning, and SLAM with ROS using Bittle and a Raspberry Pi.
Source: github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot#about-the-project
- Petoi kits
- ESP32 board
- servos
- Petoi (PetoiCamp): Creator
[](https://hardwarelab.dev/projects/opencat-petoi/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/opencat-petoi/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 28 in Robots & Rovers
Emily
An AI companion robot split across three ESP32-S3s.
- 3× ESP32-S3 (Brain, CamCanvas, InputPad)
- servos
Advanced13
Nous-Girl: StackChan robot with Hermes Agent memory
Beta firmware that turns an M5Stack StackChan into a talking desk robot with faces, DJ mode and an optional Hermes Agent brain.
- M5Stack StackChan K151 (CoreS3, ESP32-S3)
- USB-C cable
- A computer for the voice server (only macOS on Apple Silicon tested so far)
Intermediate · Our suggestion35
Jetson Orin Nano ROS 2 AMR
A ROS 2 robot with TensorRT vision, LiDAR and voice on a Jetson.
- Jetson Orin Nano 8GB
- Waveshare IMX219-120
- RPLIDAR C1
- +4 more
Advanced3
Naboo family robot
A stock mBot2 turned into a family AI agent the kids love.
- mBot2 (CyberPi/ESP32)
- Mac mini M4
Advanced1
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L5
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L51-L56
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L66-L70
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L72
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L78-L89
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L95-L100
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L76-L91
- github.com/PetoiCamp/OpenCatEsp32-Quadruped-Robot/blob/84dd6eff307eb2f4af6f9cbdf72f04e7d71beecf/README.md?plain=1#L58
