AI Raspberry Pi cat detection
A Raspberry Pi camera that spots your cat doing something it's not supposed to do and emails you; texts only through a carrier's email-to-SMS gateway.
Raspberry Pi, camera
License:
MIT
ykhli
Get an email (and an Attenborough narration) when your cat jumps on the counter
By ykhli
Demo by Yoko Li (ykhli) · Watch on YouTube · Sound on: the narration is the point.
  • Watches a room with a Pi camera and emails you when your cat does something it isn't supposed to. The creator's #1 use is catching the creator's cats on the dining table or kitchen counter.
  • Optional AI narrator: an ElevenLabs voice narrates what it sees through a speaker on the Pi.
  • Texts work too: send the email to your carrier's email-to-SMS gateway.
  • Generalises to other vision jobs just by changing the prompt.
Skill level
MIT
  • Raspberry Pi 4 or 5 (Tested on Pi 4 and 5)
  • Raspberry Pi camera (Creator links Camera Module 3 (Adafruit 5657); 'any camera should work')
  • Speaker (Only for narration or the raccoon idea) [optional]
OpenAI vision model, optional local image classifier
Accounts needed
OpenAI API key, Resend API key with a verified domain, ElevenLabs API key and voice ID (optional)
Raspberry Pi 4 or 5 Tested on Pi 4 and 5 · Price is Pi 5 4 GBRequired$130.00Adafruit, checked
Raspberry Pi camera Creator links Camera Module 3 (Adafruit 5657); 'any camera should work'Required$29.25Adafruit, checked
Speaker Only for narration or the raccoon ideaOptional
  • OS: Standard Raspberry Pi OS setup per raspberrypi.com docs.
  • OpenAI API key: required, Paid per use
  • Resend API key with a verified domain: required
  • ElevenLabs API key and voice ID: optional
Pi 5 from $130 + camera $29.25 (Adafruit); OpenAI usage extra
Prices: $130.00 at Adafruit (checked ), $29.25 at Adafruit (checked )
The Pi takes photos with picamera2. Each one (or only the ones a local classifier flags) goes to an OpenAI vision model with your prompt. Through LangChain function calling, the model decides whether to send an email via Resend, and optionally ElevenLabs speaks a narration.
Capturepicamera2 Pi
Optional local filtertorchvision Swin V2-S ImageNet classifier Pi
Vision + decisionOpenAI multimodal model (gpt-4-vision-preview in code) via LangChain function calling Cloud
NotificationResend email Cloud
NarrationElevenLabs (optional) Cloud
Skill level
Time
No time stated by the creator.
Low: venv, pip install, copy .env, add 2-3 API keys, verify a domain in Resend, run camera.py.
  • Every analysed photo is a paid OpenAI call unless you turn on the local filter (off by default).
  • Resend needs a domain you own and verify before it sends email.
  • Code pins gpt-4-vision-preview and 2024 library versions; no commits since 2024-04-30, so expect to update the model name.
  • Saves every photo it takes to a static folder on the Pi.
Things you can say or do
  • Default prompt: knows three cats by look (Cookie, Pixel, Tangerine) and, only if one is on the counter, sends a two-sentence David Attenborough-style narration.
  • Swap the prompt for a per-minute summary of what your cat is doing (the creator's tested example).
  • Turn on USE_LOCAL_MODEL so a local torchvision classifier only calls OpenAI when an 'interesting' ImageNet class (animals etc.) appears, to cut API calls.
  • Bird watching: email a daily summary of which birds came by.
  • Raccoon deterrent: play a loud sound when raccoons go through the bins (needs an external speaker; the creator hasn't tried it).
  • Plant monitor: email you when your plants are dying from lack of water.
  • Package alert: email when a package arrives at the door, and say if it's a big one.
  • Our suggestionDog-on-the-sofa alerts with the same prompt swap.
  • Raspberry Pi
  • camera
More Raspberry Pi builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/ai-rpi-cat-detection/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/ai-rpi-cat-detection/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
