Pi Pin
Open-source AI wearable based on the Raspberry Pi, in the spirit of commercial AI pins.
Raspberry Pi, mic, speaker, battery
liltom-eth
An open AI pin built on a Raspberry Pi.
Pi Pin
By liltom-eth
  • Raspberry Pi Zero 2 W (65mm × 30mm) [not stated]
  • DWEII Type-C USB 5V 2A Boost Converter Step-Up Power Module Lithium Battery Charging Protection Board [not stated]
  • 3.7V 600mAh 702030 Lithium Polymer (20mm x 30mm x 7mm) [not stated]
  • SS12F15 Panel Slide Switch [not stated]
  • Adafruit I2S MEMS Microphone Breakout - SPH0645LM4H (16.7mm x 12.7mm x 1.8mm) [not stated]
  • M1x7mm screws [not stated]
cloud AI
Raspberry Pi Zero 2 W 65mm × 30mmNot stated
DWEII Type-C USB 5V 2A Boost Converter Step-Up Power Module Lithium Battery Charging Protection Board Not stated
3.7V 600mAh 702030 Lithium Polymer 20mm x 30mm x 7mmNot stated
SS12F15 Panel Slide Switch Not stated
Adafruit I2S MEMS Microphone Breakout - SPH0645LM4H 16.7mm x 12.7mm x 1.8mmNot stated
M1x7mm screws Not stated
  1. Connect the 3.7V 600mAh 702030 Lithium Polymer battery + to the power module 3.7V + and battery - to power module 3.7V -.
  2. Connect the SS12F15 Panel Slide Switch right pin to Pi 5V (pin 2), the middle pin to Power Module 5V +, and Power Module 5V - to Pi GND (pin 6).
  3. Connect the SPH0645LM4H mic: GND to Pi GND (pin 6), 3V to Pi 3.3V (pin 1), BCLK to PCM 18 (pin 12), LRCL to PCM 19 (pin 35), DOUT to PCM 20 (pin 38).
  4. Install Raspbian or Raspbian Lite on the SD card, then sudo apt-get -y update and sudo apt-get -y upgrade.
  5. Add capture volume control in ~/.asoundrc: set pcm.dmic_hw to card sndrpii2scard, channels 2, format S32_LE, and pcm.dmic_sv to softvol control "Boost Capture Volume".
Raspberry Pi wearable with cloud AI.
  • Raspberry Pi
  • mic
  • speaker
  • battery
More Raspberry Pi builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/pi-pin/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/pi-pin/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
All 6 in Wearables
