xg.glass SDK
xg.glass is one SDK for smart-glasses apps from HKUST: camera, microphone, display and audio, working across Rokid, Meta, Brilliant Labs Frame, RayNeo, INMO, Omi and a simulator.
Rokid, Meta Ray-Ban, Brilliant Frame, RayNeo
hkust-spark
One API for camera, mic and display across many glasses.
xg.glass SDK
By hkust-spark
  • Rokid, Meta Ray-Ban, Brilliant Frame, RayNeo
  1. One extra repository is required in settings.gradle.kts: https://maven.rokid.com/repository/maven-public/ with includeGroupByRegex("com\\.rokid(\\..+)?").
  2. app module build.gradle.kts: implementation("io.github.hkust-spark:xgglass-universal:0.3.0").
  3. App module build.gradle.kts: compileSdk = 36, minSdk = 28, JavaVersion.VERSION_17.
  4. src/main/AndroidManifest.xml: CAMERA and RECORD_AUDIO permissions.
  5. For Rokid, swap SimulatorGlassesClient(this) for RokidGlassesClient(this); it implements the same GlassesClient API.
It wraps the various vendors' SDKs behind four interfaces: video in, audio in, display out and audio out. The same app code runs on any supported pair or on the simulator. Support levels vary by device; for example, RayNeo X2 supports video streaming and battery events. Android, iOS and CLI tools are included.
  • The SDK minSdk is 28; Meta support and the RayNeo glasses host require minSdk 29.
  • RayNeo support additionally requires the vendor AARs downloaded from RayNeo's developer docs.
  • Frame is only the bridge API from Maven; a working Frame integration needs the source/CLI flow because the embedded Flutter module is not published.
Open source smart glasses: AI glasses and Meta Ray-Ban apps →
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/xg-glass-sdk/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/xg-glass-sdk/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
