py-xiaozhi
py-xiaozhi is a lightweight, cross-platform multi-modal AI interaction framework built on Python’s async architecture.
- PC or Raspberry Pi, mic/speaker
- Beginner · Our suggestion
- License:
- MIT
- huangjunsen0406
Python XiaoZhi client for Windows, macOS, Linux and ARM boards
py-xiaozhi is a lightweight, cross-platform multi-modal AI interaction framework built on Python’s async architecture. It supports real-time voice streaming, vision-language tasks and IoT device control, on Windows, macOS and Linux desktops and ARM embedded platforms (Raspberry Pi, Horizon Robotics RDK, Jetson Nano).
- Real-time voice AI: Opus codec with auto frame detection, async streaming, sub-20ms latency.
- Camera capture plus vision-language model integration for image understanding and scene perception.
- A modular JSON-RPC 2.0 MCP tool server: music player, camera, screenshot, app management, weather, volume control.
- Offline wake word: Sherpa-ONNX on-device keyword spotting with custom wake word support.
- A GPIO interface for robotics control, hardware actuation and sensor integration.
- MIT (source)
- Computer: Windows 10+ / macOS 10.15+ / Linux (x86_64 & ARM)
- Microphone and speaker devices
- Camera device [optional]
- Sherpa-ONNX offline wake word, vision-language model integration, MCP tool server
| Computer: Windows 10+ / macOS 10.15+ / Linux (x86_64 & ARM) | Optimized for Raspberry Pi and edge boards | Required | |
| Microphone and speaker devices | Required | ||
| Camera device | For camera features, with OpenCV support | Optional |
- Computer for setup: Python 3.10 - 3.12 on Windows 10+, macOS 10.15+ or Linux; at least 4GB RAM (8GB+ recommended)
- A stable internet connection (for AI services and online features)
- Clone the project
- uv sync (add --extra gui for the GUI)
- python main.py, or python main.py --mode cli
A Python app in GUI, CLI or GPIO mode handles real-time voice with the Opus codec, talks over WebSocket or MQTT, spots an offline wake word with Sherpa-ONNX and exposes MCP tools through a JSON-RPC 2.0 tool server.
| Client | py-xiaozhi (PySide6 + QML GUI / CLI / GPIO) | Windows, macOS, Linux desktops, and ARM embedded platforms (Raspberry Pi, Horizon Robotics RDK, Jetson Nano) |
| Wake word | Sherpa-ONNX keyword spotting | On-device |
Clone the repo, install with uv (or pip), then run main.py in GUI or CLI mode.
- Needs a stable internet connection (for AI services and online features).
- Manually reinstall pip dependencies after each update to get new dependencies.
Run modes and protocol
# Run program - GUI mode (default; requires gui extra) python main.py # Run program - CLI mode (base install is enough) python main.py --mode cli # Specify communication protocol python main.py --protocol websocket # WebSocket (default) python main.py --protocol mqtt # MQTT protocol
- Robotics control, hardware actuation and sensor integration over GPIO.
py-xiaozhi is a lightweight, cross-platform multi-modal AI interaction framework built on Python’s async architecture, and it evolved from the xiaozhi-esp32 firmware project. The README says it is deployable across Windows, macOS and Linux desktops and ARM embedded platforms such as the Raspberry Pi, Horizon Robotics RDK and Jetson Nano. Voice uses the Opus codec with async streaming, a camera can feed a vision-language model for image understanding, and a modular JSON-RPC 2.0 MCP tool server covers a music player, camera, screenshots, app management, weather and volume control. It runs as a PySide6 + QML GUI, a CLI or a GPIO interface, with Sherpa-ONNX on-device keyword spotting for an offline wake word. D-Robotics (xiaozhi-in-rdk) officially adopted it as an upstream dependency, and there is a separate Electron desktop client, xiaozhi-desktop, with AEC echo cancellation. The original XiaoZhi ESP32 firmware is also on HardwareLab.
- mic/speaker
- huangjunsen0406: Creator
- Xiaoxia (78): xiaozhi-esp32, which py-xiaozhi evolved from
- License: MIT (source)
[](https://hardwarelab.dev/projects/py-xiaozhi/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/py-xiaozhi/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 44 in Voice Assistants & Companions
Whisplay offline voice assistant
A battery-powered Pi 5 voice assistant that works offline.
- Raspberry Pi 5 8GB
- PiSugar Whisplay HAT (LCD/mics/speaker/button)
- PiSugar 3 Plus 5000mAh
Beginner533Bring-your-own-key smart speaker
A Pi smart speaker where nothing leaves your network unless you say so.
BeginnerPrivate offline Pi voice assistant
Whisper + a small LLM + Piper, all on a Pi.
LilL3x
A modular Pi desk sidekick that starts the conversation when it sees you.
- Raspberry Pi 4 Model B
- Seeed ReSpeaker 2-Mics Pi HAT
- Pi Camera
Beginner7
AImy
Offline vision-enabled voice assistant on a Pi 5 with an LLM accelerator.
- LLM-8850 accelerator
Advanced23
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L72
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L73
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L74
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L77
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L78
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L197-L205
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L75
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L88
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L101
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L86-L93
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L56
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L178-L201
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L89
- github.com/huangjunsen0406/py-xiaozhi/blob/9bfc807d368cccac71af8d9f7042ab6b5af92030/README.md?plain=1#L106
