Echokit Server
EchoKit Server is the open-source Rust backend for the EchoKit ESP32 voice device (or your own ESP32 running EchoKit firmware).
- EchoKit ESP32 device
- second-state
Open voice-agent server for the ESP32 EchoKit.
By second-state
EchoKit Server is the open-source Rust backend for the EchoKit ESP32 voice device (or your own ESP32 running EchoKit firmware). It manages the full voice-AI loop.
- EchoKit ESP32 device (board)
- ASR/LLM/TTS pipeline
It chains speech recognition β LLM β TTS, and each stage can point at any OpenAI-compatible endpoint, local or cloud, with ElevenLabs streaming for speech. It also supports end-to-end pipelines with Gemini and Qwen Real-Time, custom prompts and MCP servers. It can run locally or use preset servers.
EchoKit Server sits between an EchoKit device, or your own ESP32 running EchoKit firmware, and the AI services. Its README describes an ASR, LLM, TTS pipeline where each stage is configured independently: speech recognition through any OpenAI-compatible API, any OpenAI-spec LLM endpoint whether local or cloud, and any OpenAI-spec voice model, with ElevenLabs supported in streaming mode. It also supports end-to-end pipelines with Gemini and Qwen Real-Time. You can deploy it locally or point it at remote inference servers, write your own prompts and response workflows, set different voices for different personas and add MCP servers. Everything is configured in config.toml, which also sets voice-activity detection, and the repo includes many examples. The README notes a required fp16 target feature when building for ARM64.
This page is a short summary written by HardwareLab. Build steps, code and photos belong to the creator; follow βView originalβ for the full project.
[](https://hardwarelab.dev/projects/echokit-server/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)HTML
<a href="https://hardwarelab.dev/projects/echokit-server/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>Related builds
All 44 in Voice Assistants & CompanionsLocal Xiaozhi on a Waveshare ESP32-S3 audio board
A Xiaozhi voice assistant that only talks to your own LAN server.
- Waveshare ESP32-S3-AUDIO-Board (ES8311/ES7210, dual mic AEC, amp, RGB LEDs)
IntermediateESP32-S3 voice frontend
An ESP32-S3 voice frontend that keeps GPIO and network actions local.
- INMP441 I2S mic
- MAX98357A amp/speaker (Gerbers optional)
OpenAI Realtime on ESP32
Espressif's WebRTC voice chat demo.
- ESP32-S3-Korvo-2 (default board; others via esp_board_manager)
Intermediate Β· Our suggestion410
KALO ESP32 Voice Chat AI Friends
Chat with several custom AI friends on an ESP32.
- ESP32
Intermediate76
ESP32 AI LLM
ESP32 voice chat with 15 LLMs, wake word and live on-screen text.
- ESP32/ESP32-S3
- display
Intermediate572
