Claude Code Stick
Hardware companion on the M5Stack StickS3 for physical button approval and voice input to Claude Code.
M5Stack StickS3
mantisblades
Physical approve buttons and voice input for Claude Code.
Claude Code Stick
By mantisblades
  • M5Stack StickS3 (ESP32-S3-PICO, ES8311 mic, 135×240 ST7789P3)
Claude Code
M5Stack StickS3 ESP32-S3-PICO, ES8311 mic, 135×240 ST7789P3Required
  1. Get a DashScope API key and save it with mkdir -p ~/.config/claude-code-stick && echo 'sk-...' > ~/.config/claude-code-stick/dashscope_key.
  2. Flash the firmware with cd firmware && pio run --target upload.
  3. Configure Wi-Fi via USB serial: pio device monitor, then wifi add YourSSID YourPassword.
  4. Install bridge dependencies with cd bridge && python3 -m venv venv && venv/bin/pip install bleak.
  5. Configure Claude Code hooks: add the entries in plugin/settings.example.json to your ~/.claude/settings.json.
  6. Start the bridge with ./start-bridge.sh. Press PWR on the StickS3 to power on and watch the boot panel; when it says READY, you're set.
Bridge between Claude Code and the StickS3.
  • No first-time Wi-Fi captive portal; the first network has to be entered via USB serial.
  • macOS only for the bridge; Linux / Windows would need a substitute for `osascript` paste injection.
  • `bridge.py:8765/audio` is an unauthenticated LAN endpoint.
  • M5Stack StickS3
More M5Stack builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/claude-code-stick/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/claude-code-stick/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
