XiaoZhi ESP32 Server
Backend service for the open-source xiaozhi-esp32 hardware project, implemented in Python, Java and Vue according to the Xiaozhi Communication Protocol.
ESP32 XiaoZhi device, server (2 cores, 2-4GB for the simplified install)
xinnan-tech
Run your own backend for XiaoZhi ESP32 voice devices
No photo in the source; GitHub repository card, served from HardwareLab.The creators’ demo videos are on bilibili, linked from the README; we only embed YouTube, X, Reddit or Vimeo.
By xinnan-tech
Backend service for the open-source xiaozhi-esp32 hardware project, implemented in Python, Java and Vue according to the Xiaozhi Communication Protocol. It supports MQTT+UDP, WebSocket, an MCP access point, voiceprint recognition and a knowledge base, with a choice of ASR, LLM, vision and TTS providers.
  • Backend service for the open-source xiaozhi-esp32 hardware project, implemented in Python, Java and Vue according to the Xiaozhi Communication Protocol.
  • Supports MQTT+UDP, WebSocket, an MCP access point, voiceprint recognition and a knowledge base.
  • Voice interaction: streaming ASR, streaming TTS and VAD, with multi-language recognition.
  • Tool calling through the client IOT protocol, client and server MCP, the MCP endpoint protocol and custom tool functions.
  • A web management interface for users, system configuration and devices, in Simplified Chinese, Traditional Chinese and English.
Skill level
  • ESP32 hardware device already connected to Brother Xia's deployed backend service
configurable ASR / LLM / VLLM / TTS providers
ESP32 hardware device already connected to Brother Xia's deployed backend service Required
  • Computer for setup: Simplified install: 2 cores 4GB if using FunASR, 2 cores 2GB if all APIs. Full module install: 4 cores 8GB if using FunASR, 2 cores 4GB if all APIs.
Skill level
  1. Choose the Simplified or Full Module installation
  2. Deploy with Docker or from source, following the linked deployment docs
  3. Pick Entry Level Free Settings or the Streaming Configuration for ASR, LLM, VLLM and TTS
ESP32 devices running xiaozhi-esp32 connect to this server, which handles streaming ASR, an LLM, TTS and voice activity detection through the providers you configure.
ServerMQTT+UDP gateway, WebSocket and HTTP servers with console management and authentication Docker or local deployment
ASRFunASR(Local) in the Entry Level Free Settings Local
VADSileroVAD Local use
LLMAny LLM that supports OpenAI interface calls, Ollama and others Interface calls
Skill level
Pick the simplified install (config files, no database) or the full module install (database, multi-user web console); both run via Docker or from source.
  • Not complete and has not passed a network security assessment; the authors say not to use it in production.
  • No commercial partnership with the third-party API providers it connects to, and no guarantee of their service quality or financial security.
  • Entry Level Free Settings vs Streaming Configuration (README table)
    | Module Name | Entry Level Free Settings | Streaming Configuration |
    | ASR(Speech Recognition) | FunASR(Local) | 👍XunfeiStreamASR(Xunfei Streaming) |
    | LLM(Large Model) | glm-4-flash(Zhipu) | 👍qwen-flash(Alibaba Bailian) |
    | VLLM(Vision Large Model) | glm-4v-flash(Zhipu) | 👍qwen3.5-flash(Alibaba Bailian) |
    | TTS(Speech Synthesis) | EdgeTTS(Microsoft) | 👍HuoshanDoubleStreamTTS(Volcano Streaming) |
    | Intent(Intent Recognition) | function_call(Function calling) | function_call(Function calling) |
    | Memory(Memory function) | mem_local_short(Local short-term memory) | mem_local_short(Local short-term memory) |
  • Entry Level Free Settings: for personal and home use, with free solutions for every component.
  • Streaming Configuration: for demonstrations, training or more than 2 concurrent users, with faster responses.
This is the piece you need if you want XiaoZhi devices to talk to your own backend instead of Brother Xia's deployed service. It is written in Python, Java and Vue, follows the Xiaozhi Communication Protocol, and supports MQTT+UDP, WebSocket, an MCP access point, voiceprint recognition and a knowledge base. The README offers two installs: a simplified one that keeps data in config files with no database, and a full module install with multi-user management and a web console, each via Docker or from source. Sizing: the simplified install wants 2 cores and 4GB if using FunASR, or 2 cores and 2GB if all models are APIs. The authors warn it is not complete, has not passed a network security assessment and should not be used in production.
Source: github.com/xinnan-tech/xiaozhi-esp32-server#readme
  • ESP32 XiaoZhi device
  • server (2 cores, 2-4GB for the simplified install)
More ESP32 builds
[![Featured on HardwareLab](https://hardwarelab.dev/badge.svg)](https://hardwarelab.dev/projects/xiaozhi-esp32-server/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w)
<a href="https://hardwarelab.dev/projects/xiaozhi-esp32-server/?utm_source=badge&utm_medium=referral&utm_campaign=launch_2w"><img src="https://hardwarelab.dev/badge.svg" alt="Featured on HardwareLab" width="188" height="20"></a>
  1. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L6-L8
  2. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L9
  3. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L224
  4. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L231
  5. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L233
  6. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L196-L203
  7. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L190
  8. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L192
  9. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L48
  10. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L170-L171
  11. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L223-L235
  12. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L196-L198
  13. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L291
  14. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L254-L264
  15. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L165-L203
  16. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L157
  17. github.com/xinnan-tech/xiaozhi-esp32-server/blob/eb9dc8ca0fc8a30bc8afb0f302dcfc1578f76a7b/docs/readme/README_en.md?plain=1#L155
